Re: 560 turns....But NO spark
Posted by El Toro on October 09, 2011 at 15:52:57 from (108.3.225.100):
In Reply to: 560 turns....But NO spark posted by Matt_in_Michigan on October 09, 2011 at 11:32:38:
You probably need to bring No1 piston to TDC on the compression stroke. Then take a look at the rotor to see where it's pointing. If it's not pointing to the No1 plug tower you need to remove the distributor and rotate the rotor so it's at the No1 plug wire on the cap.
Once you have it installed clean those points with some 320 wet or dry. Hal
