Re: changed plugs and working much better
Posted by The tractor vet on October 09, 2011 at 17:00:15 from (76.212.225.127):
In Reply to: Re: changed plugs and working much better posted by rustred on October 09, 2011 at 11:45:52:
Ya should have been with me yesterday , I was on a 706 gasser that i sold to a close friend some twenty plus years ago and just did a major on the engine this spring.I spent about 12 hours on it pulling silage wagons with it , these are 18 foot H/S rear unload we were filling them to the roof and probable weighing in at around 28-30000 lbs . Our ground over here has shell we say a roll to it and some of them little humps and bumps are STEEP . It was working the 706 big time and it would pull down to 1000-1200 RPM in second high with a good run on the hills . 13000lb. tractor with 28-30000 behind ya on a hill ya had best pick a gear that will carry ya over the top with out pulling the T/A as if ya do you will spin out and then you can not hold the load on the hill and things get ugly real fast . she was a pawen each load up the hills at times she was getting a little light in the ft. end . Normally we do not use the 706's to pull these wagons but the rest of the fleet were doing other stuff .
