Running a plug that is too hot for the engine/conditions will damage the plug but not so much the engine. Thr hotter plug has less insulation, therefore the electrode runs at a higher temp, (to burn off deposits) The entire plug may run a little hotter also, but this has very little effect on combustion chamber temp, as it must all be transferred via the mass in the cyl head. Negligible cht change noted at the piston dome, as the combustion is at the same time, and same place as a cooler plug. 89 octane is higher than 99% of the farmers used in 1946.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
