Re: changed plugs and working much better
Posted by IH fan on October 10, 2011 at 08:33:41 from (99.91.8.97):
In Reply to: changed plugs and working much better posted by The Gambler pulling team on October 09, 2011 at 10:41:25:
... vet is right... in most cases, a semi- or fully mounted plow will pull easier than a pull type. Load transfer is just better on most tractor/plow set-ups, and with a good draft control system, it gets even better. I highlight most because there are going to be exceptions to almost every rule.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
