Re: Farmall M electrical question
Posted by paramedicchuck on October 10, 2011 at 14:26:22 from (173.89.149.89):
In Reply to: Farmall M electrical question posted by paramedicchuck on October 01, 2011 at 19:58:13:
I was able to rewire the lights with 12 ga wire, replace the fuse, and check the electrical system with a test light. Everything is working, except....
I don't get a positive charge on the ammeter. When the lights are on, regardless if the tractor is running or not, I get a negative reading. When the lights are on high beam, the discharge rate is increased, so it seems the gauge is working.
Any thoughts on this issue? I am going to research polarizing the generator....if that doesn't work, anyone have any words of wisdom?
Thank you!
Chuck
