Re: Hi All, New Guy...
Posted by Janicholson on October 10, 2011 at 19:21:37 from (67.72.98.45):
In Reply to: Re: Hi All, New Guy... posted by azacher on October 10, 2011 at 17:18:45:
When you do this flushing, Put the hose in a bucket
and start the tractor with the hydraulic valve to
the open hose already turned on so none is
circulated beck into the reservoir. When stopping
the 3 quart limit, shut the tractor off, don't shut
the valve off first. again preventing mixing of
fluids. If a cylinder is extended, push it
manually to the other end bleeding its contents into
a pan. There will be some trapped residual old oil,
but not much. Jim
