What will this Sickle Mower Fit??
Posted by AL Farmall Boy on October 10, 2011 at 19:22:11 from (98.83.136.115):
A friend of mine is looking to purchase a Sickle Mower for his Farmall SUPER A tractor. He"s found one that was mounted on a Farmall 140 tractor. Will it fit his Super A. I have reason to believe it will since they are basically the same tractor, but would like to be sure since he"ll be traveling so far. ANY HELP WOULD BE APPRECIATED. Also, I am going to post a picture of it. If someone knows the model of it, that would also help.
THANKS!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
