Posted by Owen Aaland on October 10, 2011 at 21:00:31 from (216.47.32.147):
In Reply to: Super M Tranny Oil posted by Mark in Upstate on October 09, 2011 at 18:33:29:
You've got to get to a 706 or larger tractor to have a transmission brake.
With the release of HY-Tran it also became the recommended lube for the older tractors replacing the 90 weight lube oil. There is no harm in using it, it just has some disadvantages compared to the heavier oil.
Something else you may run into with Hy-Tran is gear rattle at low idle when the transmission is in neutral. The crankshaft speeds up each time a cylinder fires and then slows down again until the next cylinder fires. This uneven speed can cause noise with the thinner oil because of the back lash in the transmission gears. A thicker coating of because of higher viscosity will cushion the gears a little better.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
