Re: Idea for a sweeper, want input !
Posted by Super-H-Mike on October 11, 2011 at 10:32:04 from (76.164.146.21):
In Reply to: Re: Idea for a sweeper, want input ! posted by Wardner on October 11, 2011 at 10:21:18:
I like that idea of running the pump from the belt pulley, that was my first idea too. A lot easier to run the hoses and mount the hydro-motor than belts and pulleys I know, but still too much $ for my use... A swinging tensioner pulley with a strong spring would compensate for the up and down of the loader I believe, which would only have to up and down a couple feet or less anyway. Do you think the broom would HAVE to be angled to work? If so, I d likely go back to my idea of a trailing pull-type unit instead . Thanks !
