Re: Paulson loader- will a paulson that was on a 300 fit a M
Posted by mkirsch on October 11, 2011 at 11:50:07 from (64.80.110.75):
In Reply to: Paulson loader- will a paulson that was on a 300 fit a M? posted by NolanJae on October 11, 2011 at 08:28:56:
You don't plumb in Tee's.
All you have to do is mount the control valve somewhere convenient. Run a hose from the right hydraulic port on the belly pump to the IN on the valve. Run a hose from the OUT on the valve to the fill pipe on the belly pump. Done.
