Posted by El Toro on October 11, 2011 at 17:09:27 from (108.3.225.100):
In Reply to: distributor to mag? posted by mike paulson on October 11, 2011 at 16:51:26:
You look to see your rotor is pointing on your distributor and make a sketch so you don't forget. Disconnect the battery voltage wire from the ignition switch to your auto coil and remove the wire and coil.
Once you have your sketch made where the rotor is pointing remove the distributor. THEN DON'T MOVE THE ENGINE. Rotate the rotor on the mag so it points to the same spot as in your sketch and install the mag. You need to install a switch that will ground out the mag to stop the engine. You need to make sure the mag is firing before installing it. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
