Re: distributor to mag?
Posted by Janicholson on October 11, 2011 at 17:26:30 from (67.72.98.45):
In Reply to: distributor to mag? posted by mike paulson on October 11, 2011 at 16:51:26:
With no offense to mag users, or those who want to or must operate W/O starting Batteries..... Magnetos are OK for hand cranking a tractor if the battery is dead. A distributor has a full range of centrifugal advance. Curved to follow engine performance, the Distributor retards the timing correctly to let tractors idle smoothly and with good response and efficiency at modest throttle settings. A mag has only two settings for timing, one for starting (impulse delay at TDC) and full advance for all running conditions from idle to Wide open. Distributor tractors are substantially smoother at idle. Manufacturers would be using them today if they were better. Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
