I put the shaft in without all the other stuff on it like hydrostatic pump and swash plate. Get the shimming for correct amount of end play. It requires pulling that front bearing cup to add or subtract shims. Been many years since I did it though so may be forgetting a few things. I just never liked to do it the way the book shows. End result is the same only this way you can actually measure end play. One thing you have to remember about measuring end play on any tapered roller bearing shaft is you turn shaft several times and then you measure by prying shaft or pulling shaft. After you pry or pull it one time you have to rotate it again to get an accurate measurement. I never actually realized that myself until they showed us this procedure when at service training on the CaseIH magnum tractor transmissions. And yes, those charge pumps do tear up.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
