Posted by tempola on October 11, 2011 at 19:59:37 from (207.119.117.250):
In Reply to: Re: Grinding Gears posted by Jimb2 on October 11, 2011 at 15:48:29:
Our Super c had that problem for years, replaced clutch, pressure plate, throwout bearing and pilot bearing......little improvement.
Last year, it started knocking right at the back end of the torque tube.. I looked up at the shaft while it was running through the clutch adjustment hole in the bottom of the torque tube. it was running crooked, and not true.
I split the tractor and replaced the trans joint. it was totally worn out. The tractor shifted easily then.
My guess that the worn joint caused the rear of the shaft to wobble, and that would cause the clutch disc to wobble slightly fore and aft in the flywheel giving just enough bind not to spin down..
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
