Re: Farmall Cub stalling out
Posted by JRSutton on October 12, 2011 at 13:21:07 from (75.130.109.233):
In Reply to: Re: Farmall Cub stalling out posted by Mt.Man on October 11, 2011 at 14:19:28:
Quick check - see if it stalls with the carb choked (half way or so). My first guess is that the governor's opening the carb up more, since more power is needed for the higher gears, and it's starving for gas.
If the problem goes away while choked, then you're not getting enough gas THROUGH the carb (clean it).
(If choking it doesn't change anything, it doesn't mean your carb IS ok though.)
You might not be getting enough gas INTO the carb in the first place, less likely (since it runs in low gear), but worth checking. Check your fuel line.
I'd also check for a weak spark, and clean points. Very possible it's an ignition problem.
I'm also a big fan of adjusting the valves anytime you have any kind of engine trouble. Just because.
While it's running ok in low gear, what happens if you go up a steep hill? Does the govenor maintain a steady ground speed (increasing the rpms)?
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
