Re: IH M serial number
Posted by rustyfarmall on October 12, 2011 at 14:13:12 from (216.248.71.224):
In Reply to: IH M serial number posted by TK54 on October 12, 2011 at 13:24:24:
The engine serial number is stamped into a rectangular, raised area just below #1 spark plug. Depending on the year of your M, and IF the engine is original, that number will be the same as the chassis serial number.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
