282 valve seals
Posted by a bart on October 12, 2011 at 16:28:46 from (98.244.94.172):
i got a victor head gasket set it had 18 valve seals in it 12 looked a little bigger 6 a little smaller when i took the engine apart it only had them on the intake just wondering if the exhaust needs them the kit does cover several engines also if i wanted to add a turbo would it make a difference if they were seals on both valves
