Re: H Oil Pressure
Posted by Janicholson on October 12, 2011 at 19:57:18 from (67.72.98.45):
In Reply to: H Oil Pressure posted by George rausch on October 12, 2011 at 19:47:08:
Nope. They rub with the gauge pegged from the beginning. I believe they see 80 PSI from the factory. Consider that pressure to be just fine. The pressure is an indication of delivery of oil to bearings that are not blatantly worn. Engine bearings in tractors use the oils lubricity, not the pressure to "float" the components. Oil pressure is more important in a Hydraulic lifter engine to keep the lifters pumped up, but even that is more of a supply issue than pure pressure. Jim
