Re: WD9 - what do you use them for now adays
Posted by Don R of MN on October 12, 2011 at 20:25:59 from (205.243.121.147):
In Reply to: WD9 - what do you use them for now adays posted by arod on October 12, 2011 at 15:39:00:
Thay are a neat big old tractor. I have a W9, SWD9 and a 600 diesel. But the biggest problem is parts. If you need to go into the engine a set of gaskets will run close to $300,main bearings $150 each for W9 gas, $500 plus diesel mains and you better not need under size, piston and sleeve sets $400 to $500 a hole. Trust me on this as I have went thru two diesels and one gas. But the nice thing is you don't see many at most shows and that is why I like them. P.S. my 600 is in the july issue of Antique Power.
