Re: finished plowing
Posted by don656 on October 13, 2011 at 06:29:47 from (75.179.143.177):
In Reply to: Re: finished plowing posted by The Dukester on October 12, 2011 at 17:09:05:
I agree with you. I like plowing. I really don't think this tractor and plow can do any better than an acre per hour, though. The plow is all the tractor wants. I had to use the TA a lot and in a lot of places had quite a bit of wheel slip. Seems like I need a 100 hp tractor and 10,000 lbs weight for this plow! Growing up, I remember my Dad pulling 3-14's with a Farmall M in 3rd gear. That old M would make a lot of noise and my dad would comment "that really makes her bark". When the 656 gets loaded down, the sound is more like a whimper.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
