Re: cub front wheel bearings
Posted by gene bender on October 13, 2011 at 11:16:12 from (67.55.227.142):
In Reply to: cub front wheel bearings posted by Martin Kellner on October 13, 2011 at 10:53:28:
The rim is loose on the hub if the bearing goes out the wheels will tilt sideways the clicking sound is probably loose bolts on the hub you will probably need new ones as the threads are probably shot and mite not tighten up.
