Re: finished plowing
Posted by Lmack on October 13, 2011 at 15:15:32 from (74.176.39.65):
In Reply to: finished plowing posted by don656 on October 12, 2011 at 10:49:59:
Something is not right. I plowed with a 656 in heavy soil pulling a IH 3-16 flip plow (plows deeper due to plow weight) and high third was typical except in heavy sod. My uncle pulled four 16 mounted beam plow with his. Mine was a diesel though. That had to be some tough soil you plowed. Must have been a long time since it has been plowed up.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
