Re: 300 utility exaust convert to top
Posted by bkpigs on October 13, 2011 at 19:31:22 from (24.182.236.220):
In Reply to: 300 utility exaust convert to top posted by chrism in tn on October 13, 2011 at 19:23:23:
My pop's tractor is vertical (like to convert it to lower someday). If you take the left hood panel off you will see that attached to the manifold is a 90 degree elbow. Soak and I mean soak the 2 bolts with PB Blaster, ATF, any kind of penetrating oil or magic witch potion (personally don't use WD-40, don't think it does much) for many days to weeks. Remove the bolts and invert the elbow. Cut a hole in the sheet metal and attach a muffler. You may need to cut some pipe and/or weld some pipe but that is the jist of it.
