Re: super A engine rebuild
Posted by gene bender on October 14, 2011 at 04:57:57 from (67.55.227.142):
In Reply to: super A engine rebuild posted by JRSutton on October 13, 2011 at 18:14:40:
In the engines i have rebuilt never raninto a bad cam they run in the area of plenty of lube so they just dont wear. And as others have said there are no bearings. You should pull a sleeve before getting parts wo you know which sleeve you have as your block mite even be able to use the 3 1/4 bore. Remember its 50 pluss yrs old and you wont know what is there till you have the sleeve out. New sleeve,wrist pin and rings start at 52 each complete kit with bearings and all gaskets will run little undrr 400. You need to remove the engine to be able to do the complete overhaul.
