Re: Farmall Cub... throttle snaps open too quickly.
Posted by mkirsch on October 14, 2011 at 05:11:40 from (64.80.110.75):
In Reply to: Farmall Cub... throttle snaps open too quickly. posted by John_PA on October 14, 2011 at 02:21:57:
Fast idle only adjusts the RPM of the engine, so process of elimination, I would try the bump spring adjustment.
You kinda indicate that you've gotten combine governors before... How did you fix the problem then? Should be able to do the same thing now.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
