130 still having problems
Posted by Brian on August 24, 2000 at 05:29:44 from (152.163.213.189):
Friends 130 that is running 6V is having a problem. I posted a message about a week ago and was told to check the voltage on the resistor and it should be around 7V, well he says he's only getting 5-5.5V, and also it will be running fine like when cutting the grass and he'll shut it off and sometimes if he tries to start it right away, it just sits there and cranks and cranks, he usually ends up hand cranking it and it will eventually start and run very ruff. It coughs and sputters then it runs fine then sputters a little more etc. Sorry for length, just trying to explain it as best I can being an outside party to the situation, Thanks....Brian
Post A Followup
: Re: 130 still having problems
