Posted by Andrew Z on October 14, 2011 at 05:53:19 from (72.10.122.33):
In Reply to: Re: H axle seals posted by David G on October 14, 2011 at 05:37:44:
changing the bull pionion seals is far more complex then changing the axle seals. There are a couple of ways to do it but the 'correct' way is to remove the top cover or the pto to gain acess to the bull grears, remove the bolts on the axle ends and pull the axles out. ( you can do the seals on them now as well) There are 4 bolts that hold the bearing cage in there. With these removed you will be able to pull the bearing cage out and change the seal. I would really get a manual before you get into that job. Not a super hard job but not a walk in the park. The other way to do it is to try and pick and pry the seal out with hooks and such, i have never done them this way just have heard it talked about. Im sure there are lots of post in the archives on here about this, the M is pretty much the same set up as well you can reference them as well. Supers and beyond are diffrent.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
