Re: finished plowing
Posted by IH fan on October 14, 2011 at 20:02:28 from (99.103.254.74):
In Reply to: finished plowing posted by don656 on October 12, 2011 at 10:49:59:
Lot of difference in soil types, but we plowed with 2 JD 60s (37 dbHP) which is about mid-way HP-wise between an M and SM and had no problems in any soil we farmed. Plows were 3x14" JD 55 and the other an IH... don't remember the model but had high speed moldboards and seemed to pull easier than the JD. Later Dad had a 460 (46 dbHP) and pulled an IH 3x16" in the same fields.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
