Re: Farmall M belly pump removal
Posted by Bob M on October 14, 2011 at 20:33:25 from (69.207.87.100):
In Reply to: Farmall M belly pump removal posted by Karl Z on October 14, 2011 at 20:02:06:
Karl -
Belly pump removal is straightforward. Only caution are the pump is HEAVY (also it is top-heavy). DON'T let it get away from you when lowering it from the tractor!
If you are working alone replace each of the (4) mounting bolts with sections of threaded rod + nuts. Then lower the pump gradually by gradually running the nuts down the rods. (It's not fast but it's easy and safe!)
