I Install all my heaters with ball valves at the engine than plumb hoses from there. That is because if you have to replace compents or simply don't heat in the cab in the summer time you just close the valves. I also prefer a tank heater over block heaters because if heater fails instead of draining cooling system you just shut off valves and replace faulty componet. Seem likes heaters fail in the worst weather when tfey are needed the most! I changed the tank heater in my backhoe during a snowstorm in about ten min. and only lost a cup of coolant because I had shut-off valves in the right places. I have a Cat engine in the semi with a block heater in a hard to get to location. With 44 qt. cap. system draing under less than ideal conditions can be a real pain. Armand
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
