Re: Super M hydraulics problems (long post)
Posted by D Slater on October 15, 2011 at 17:33:14 from (184.15.3.93):
In Reply to: Re: Super M hydraulics problems (long post) posted by jtbartlett on October 15, 2011 at 16:14:50:
Another suggestion along with Jims. Think the drain hole is only 1/4 pipe thread. You can do the return like IH did when a two way valve was added to that hydraulic system. Install a tee where suction line exits the reservoir or along the way and dump return oil there. Other alternatives, make another opening in reservoir. Or gut reservoir valving and send pressure line straight to valves with a pressure relief added. Dump oil in the former pressure hole or one of the openings on rear of the reservoir.
Lots of working tractors with that reservoir and loaders had a extra small tank made up to screw in the fill hole with vent on top or similiar extra capacity.
