Re: farmall H wiring
Posted by Novice with Case on October 15, 2011 at 20:14:23 from (24.178.95.41):
In Reply to: Re: farmall H wiring posted by gene bender on October 15, 2011 at 13:25:34:
It doesn't make any difference since it is going to have power on either end as long as the fuse has not blown. I do have a question on an H voltage regulator. The tractor is still on a 6 volt positive ground. I found a new old stock regulator which has no markings other than the number 1409 on the bottom and Positve next to the lead going to the generator on the bottome of the regulator. I was told this meant it was a positive ground but do not want to mess up something else if it is not. Any help would be appreciated.
