Super A Final Drive
Posted by Kenny Upton on October 16, 2011 at 11:44:59 from (166.82.32.246):
I'm helping a friend with his fathers Super A. The left axle shaft has about 1 inch play in it form side to side. How do you tighten the play up? We took it apart and the ball bearings look good the bolt on the inside of the axle was tight. There is a 4 7/16 long tube spacer between the outer bearing and bull gear. Should i make a longer one? Any thoughts?
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
