Re: 815 Combine Forward/Reverse Cable
Posted by Janicholson on October 16, 2011 at 14:39:15 from (67.72.98.47):
In Reply to: 815 Combine Forward/Reverse Cable posted by Rich in Ont. on October 16, 2011 at 11:09:07:
Put a rubber pressure hose (150psi or better) over the end of the cable and hose clamp it to the housing to make a seal. Use at least a foot of hose. Put a air valve in it from a tubeless tire (check used ones at a tire store) fill the hose with ATF, put the air fitting in the end, use a clamp or two to keep it in, and put some pressure in the fitting with the hose higher than the cable.
Sure works for me. Jim
