The belly pump only puts out 7-800 psi, I think, however the weight you can lift is dependent on the size of the cylinders and the geometry of how far the weight is from the pivot point. I know I was able to lift an Allis B rear end/transmission/rear hubs/final drives assembly with the loader on my H which has fairly small cylinders, so I would think it would work to lift your mower. Zach
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
