Posted by IH fan on October 16, 2011 at 20:50:52 from (99.103.254.74):
In Reply to: water in hydralics posted by Smd1925 on October 16, 2011 at 17:56:49:
Darn near impossible to get all the water out of a system with one change, unless you disconnect every hose, valve, pump and cylinders and completely drain them. Used to get leaks in heat exchangers in our test stands and even with draining everything we could get loose or open, there would still be water hiding in there somewhere. When we got as much out as possible, we left the reservoir open and heated the oil above boiling while circulating it. sometimes took a day or two to boil out that last water. One point here.... it takes surprisingly little water to make oil "milky" below the boiling point of the water in it and above the boiling point, it can appear to be clear. If you have changed it 3 times, there is probably not much water left. Water is highly errosive in high pressure systems, but if your system is 1500psi or lower, it can probably tolorate a little water.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
