Re: H-hydraulic question
Posted by George rausch on October 17, 2011 at 03:08:23 from (64.85.221.4):
In Reply to: H-hydraulic question posted by linda m on October 16, 2011 at 21:50:53:
Very sorry to hear of your loss. The Lift-All belly pump should relaese pressure when you slightly lift the circle-thing-lever up a little bit, so the little detent bar on the bottom of the lever clears the opening, and you keep on pushing the circle-thing, all the way down. It should push down another few inches, and the pressure should then release. You then lift the little bar back up in the opening, and it will rest against the opening for storage.
