Cracked Block on 39- F20
Posted by SDE on October 17, 2011 at 16:42:48 from (174.124.47.113):
third party image
I have purchased my Grandfather's F-20. My Uncle died before he could finish the restoration. The block was sitting cross-wise on the frame rails. It had the crank installed but not any sleeves. When I got it home I noticed a crack between the #1 and #2 cyclinders. It had to have happen during the trip home. How will that have to be repaired?
