Re: farmall f20 backfiring
Posted by JRSutton on October 18, 2011 at 04:29:15 from (75.130.109.233):
In Reply to: farmall f20 backfiring posted by geeze on October 17, 2011 at 22:53:26:
If its backfiring out the carb, it's usually a valve and/or timing issue.
If it's backfiring out the exhaust, it's usually carb or ignition related.
("usually" of course does not mean "always")
Since it runs consistently for 7 seconds, I'd (loosely) rule out valves and timing - if were either of those it should happen immediately)
Assuming it's in the exhaust, it means you're getting unburned fuel exhausted into the exhaust manifold. It may take a little time (7 seconds perhaps) for the exhaust manifold to get hot enough to ignite that unburned fuel.
As counterintuitive as it sounds, that can often happen from the fuel mixture being too lean to burn fully in the cylinder, but it can also happen if it's too rich.
Either way, it's definitely worth playing with the carb.
Another issue could be a cylinder missing, passing unburnt fuel into the exhaust. So check for a good spark on all cylinders, and clean up your points, etc.
Make sure your plugs are clean, and wires are good. Make sure everything is dry.
If still having trouble, adjust your valves and take a closer look at your ignition components.
Essentially, check everything an anything that has to do with getting a proper burn in each cylinder.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
