Re: Super M hydraulics problems (long post)
Posted by mkirsch on October 18, 2011 at 05:22:55 from (64.80.110.75):
In Reply to: Super M hydraulics problems (long post) posted by jtbartlett on October 15, 2011 at 13:41:28:
Your problem is that you're using the fill pipe as the return line.
I can't even get oil in that pipe with a funnel on mine. It runs VERY slowly. You're trying to shove a bunch of oil in there under pressure! No wonder it squirts out!!!
Look over the hydraulic block. There are pipe plugs in several locations on the body of the block. These are potential return ports. I used the 1" plug on the right rear of the block.
If your hydraulic pump isn't making funny noises, getting hot, etc., AND the loader seems to have good lift capability, there's nothing wrong internally.
Oh yeah, in your last picture it looks like you haven't connected the OUT side of the third (left) valve! Oil should be squirting out there like crazy!
