Agreed that'd be the most likely cause of it leaning out. Check the gas flow to the carb. If that's fine - you can try giving the carb a few good smacks with something solid (don't go crazy) - sometimes the floats stick, blocking the flow.
If that doesn't do anything, you might have to operate on the carb to see what's going on.
Another quick easy test is to try running it half choked. If it runs ok then, that means you ARE getting enough gas to the carb, but might be running too lean through the carb. Try richening it up a bit before operating.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
