Re: super A steering box
Posted by JRSutton on October 18, 2011 at 13:07:42 from (75.130.109.233):
In Reply to: Re: super A steering box posted by merlynr on October 18, 2011 at 12:40:18:
a few pictures for you- and a few things I forgot about.
on the sector gear, there's a keyway - on mine there was a lot of slop between the woodruff key/gear/and shaft. I put another beer can shim in with the woodruff key to tighten that up. You can see me measuring that gap with a feeler guage.
Another picture is of the square hole on the steering arm.
Then - a picture of the axle tube with the pivot pin. I had forgotten that on mine, it had cracked, and that was allowing for a LOT of wobble and looseness - you can see my weld all rusty. Worth checking when you get yours apart.
I also realized that I pulled the pin and axle first, then took off the steering housing by itself.
finally - just a picture of the sector gear back in the housing.
From these pictures, I don't think the sector gear is reversible - it has one side that sticks out more - not sure if you can work around that or not, but at a minimum, it's definitely not symetrical.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
