Re: H Steering shaft
Posted by D Slater on October 18, 2011 at 13:47:46 from (184.15.3.93):
In Reply to: H Steering shaft posted by AL Moyer on October 18, 2011 at 06:18:10:
Farmall 300 or 350, $10.00 bushing will work. You would need to bore the old support to install the bushing. Connecting rod bushing from a C175 engine works also. Think you can still get a new center casting at CIH for around $75.
Like the others pointed out the shaft may be worn as much or more than the bushing.
If you decide to have the steering shaft built up it can be made oversize where the center support is then bore support to fit. Can't go any bigger than the shaft size at the front bushing and seal though.
