Re: F-20 cracked block revisited
Posted by RedRoundhead on October 18, 2011 at 17:28:00 from (108.115.78.33):
In Reply to: F-20 cracked block revisited posted by SDE on October 18, 2011 at 15:41:31:
You will need to have the head surface where the weld repair was done milled flush, and the sleeve counterbore and through bore will have to have the weld removed as well. Those steps may cost more than the weld job. Also, is there press on those sleeves? The block may be "sprung" open, out of tolerence, and may not hold a sleeve an longer. They may be out of round. It would be unfortunate to have a weld repair done, only to find the block out of specification.
Best of luck!
