The likely hood is a manifold leak. Either at the head, at the carb, or internally between the Exhaust and intake where they touch.
While it runs, take a propane torch (with the tip taken off so only propane comes out) and with it turned on just a little, move it all around the intake system. (do this outside, and have good sparkplug wires) If there is a leak, the engine will pick up speed and run correctly! If none, (and you are sure the carb is correct!!!) then pulling the manifold to check for an internal crack is needed. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
