Re: 1947 farmall cub tranny
Posted by gene bradley on October 18, 2011 at 17:50:11 from (74.194.120.142):
In Reply to: Re: 1947 farmall cub tranny posted by whig on October 18, 2011 at 17:09:19:
whig with a clean pan drain the gear case if the lube is clean you can reuse it if it has water in flush it out only holds about 2qts lube fill plug is rear of shift cover in friendship gene bradley
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
