Posted by Janicholson on October 18, 2011 at 17:56:36 from (67.72.98.45):
In Reply to: gear oil leak posted by ptb275 on October 18, 2011 at 17:13:40:
Take a piece of white printer paper. Pull the dip stick and place a drop of the oil on the paper. Check the trans oil and using the dipstick, or a straw to get a sample, put it next to the engine oil. Do the same for hydraulic oil. then collect a drip from the underside, and compare the spots. This will tell you which it is. Will you need to split it? Yes. Will a seal conditioner help. Maybe, but they are specifically made to swell rubber and make seals stop leaking while you sell the unit to someone who then needs to replace all the seals as they fall apart. Not recommended by me. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
