Re: F-20 cracked block revisited
Posted by Tom Fleming on October 18, 2011 at 18:06:04 from (67.20.249.95):
In Reply to: F-20 cracked block revisited posted by SDE on October 18, 2011 at 15:41:31:
Teddy, you are not too far off. Still a bit hard to tell from the pictures, but I have run some C-113 engines with cracked blocks without issue. You are correct, once the head is torqued down, not much is going to move around. Now, I am agreeing with you based upon where the crack is.
A good welder should be able to just weld this in the water jacket area, and not do anything on the gasket surface deck. These old blocks are pretty forgiving in many ways. The down side to putting her back together without doing anything is the risk that she leaks.......she certainly isn't going to fly apart ( or at least that is the lowest risk of them all).
IMHO.
