Re: F-20 cracked block revisited
Posted by Tom Fleming on October 18, 2011 at 18:38:02 from (67.20.249.95):
In Reply to: F-20 cracked block revisited posted by SDE on October 18, 2011 at 15:41:31:
Die grinder with a 3/8" conenose on it. 30 mins of grinding. another 30 mins with a rosebud to evenly heat up the block. 15 mins with 2-3 nickel rods (depending upon how much he grooves the crack). Then another hours worth of occasional heating with the rosebud to cool her down right. Peen weld when cool to relieve the stress. As I said, no finish work on this to make it look pretty.
good to go. 3 hours at $75 per hour, plus costs of nickel rod and gas consumption. A good welder knows the CFM of his nozzles and prices accordingly. most of the time here is pre-heating, and controlled cool down. Not many local welders have an oven big enough for a block this size.
I would guess $250-$300 would do it. Of course my opinion again.
