Re: farmall h light wiring
Posted by SLH on October 18, 2011 at 19:05:14 from (70.249.209.148):
In Reply to: Re: farmall h light wiring posted by George rausch on October 18, 2011 at 18:32:24:
George , I wired the switch like the factory diagram shows I was also checking the light wire with the test light lead on the starter button ground and not the positive ground if this makes any difference I may have to go back check the wiring in the switch.
